The Daily CTD
Community Browser
Trusted Enthusiast ‎03-15-2016 05:54 PM
5 Comments
Process Models
Which of the following is not a process model sequence file that ships with TestStand?
a) DefaultModel.seq
b) BatchModel.seq
c) ModelSupport.seq
d) ParallelModel.seq
Trusted Enthusiast ‎03-07-2016 09:44 AM
2 Comments
Adapters
Which of the following adapters can call code written in LabVIEW?
a) .NET Adapter
b) None Adapter
c) HTBasic Adapter
d) LabWindows/CVI
e) C?C++ DLL
Trusted Enthusiast ‎02-29-2016 09:13 AM
1 Comment
Configuration Files
It is a requirements that all TestStand Configuration files be in the same folder except for 1.  Which one does not have to reside with the othere?
a) testexec.ini
b) users.ini
c) stationglobals.ini
d) toolmenu.ini
e) engineparts.ini
f) analyzer.ini
BONUS: How do you change the location of that single config file?
Trusted Enthusiast ‎02-16-2016 09:28 AM
1 Comment
Choosing The Right Process Model
You are developing an automated test to test 5 widgets.  These 5 widgets will be placed inside of a temperature chamber and ran through 5 temperature cycles.  Discuss which process model you would choose and why?  If you would modify the model how would you modify it?  Which callbacks would you use in your client sequence file?
Trusted Enthusiast ‎02-15-2016 08:45 AM
0 Comments
Tracing
If Trace Into Entry Points is checked in Station Options and an Execution Entry Point has Hide Entry Point Execution checked in the Model tab of the sequence properties then which of the following statements is True?
a) You cannot check Hide Entry Point Execution for Execution Entry Points.  This option is only available for Configuration Entry Points
b) Tracing will not be shown for the Execution Entry Point because Hide Entry Point Execution overrides the Trace into Entry Points option
c) You must also check Trace into Separate Execution Callbacks for the tracing to be shown during execution
d) The sequence call step which calls the Execution Entry Point must have tracing marked as "Disabled" and the Allow Tracing into Sequence Calls Marked with Tracing "Disabled" must be checked in order to disable tracing for the Execution entry point
Trusted Enthusiast ‎02-11-2016 09:02 AM
3 Comments
Automatically Login Windows User
Which of the following is true about checking the Automatically Login Windows System User on the User Manager tab in Station Options?
a) The FrontEndCallbacks.seq file is ignored completely and does not execute, the engine automatically logs the user in
b) The windows user is automatically added to the Users.ini file as an Operator and then logged in
c) If the user does not exist in Users.ini the login dialog appears and prompts the user to log in
d) The windows user must be named Administrator or Operator when first logging into TestStand
Trusted Enthusiast ‎02-09-2016 07:49 PM
2 Comments
Error Handling
If On Run-Time Error: in the Station Options is set to Ignore and Ignore Run-Time Errors in the step Run Options is checked then when the step throws an error which of the following will happen.
a) The error dialog will still show because the Sequence Properties needs a checkmark in Immediately Goto Cleanup on Sequence Failure to totally eliminate errors
b) SequenceFilePostStepRuntimeError will execute
c) No dialog will appear and the error will be discarded
d) The engine will show the error dialog but RunState.Execution.ErrorObject.Occurred will be set to false
Trusted Enthusiast ‎02-09-2016 09:02 AM
5 Comments
Step Actions
Which of the following step actions execute first:
a) Pre-Expression
b) PreStep Substep
c) Call Module
d) Allocate Step Result
