The Daily CLAD
Community Browser
Re: LabVIEW Shortcuts
SercoSteveB
Link the following LabVIEW shortcuts (1-5) to the associated description (a-e)?
1. Ctrl-L
2. Ctrl-Enter
3. Ctrl-U
4. Ctrl-I
5. Ctrl-M
a) Reroutes all wires and rearranges block diagram objects automatically
b) Display the VI Properties dialog box
c) Ends text entry
d) Changes to run or edit mode
e) Displays the Error List window
Comments
ersmt444
1. Ctrl-L           e) Displays the Error List window
2. Ctrl-Enter    c) Ends text entry
3. Ctrl-U          a) Reroutes all wires and rearranges block diagram objects automatically
4. Ctrl-I            b) Display the VI Properties dialog box
5. Ctrl-M          d) Changes to run or edit mode
nik35324
e,c,a,b,d
crossrulz
Knight of NI
For the Ctrl-Enter, it actually depends on a setting in the options (something like "End text entry on Enter").  So on my setup, the Ctrl+Enter actually inserts an End Of Line.
1 E (I honestly did not know this one.  I just use the broken run arrow.  Luckily I knew the others so I got it by process of elimination)
2 C
3 A (Diagram Cleanup)
4 B (use this one about 10 times a minute sometimes)
5 D (useful for seeing how your GUI will look when ran without actually running the VI)
GCentral
MrStevenUND
I didn't know 1, I use the broken arrow like Crossrulz.  Also never used 5.
Here's a few other keyboard shortcuts for use in the quick drop menu, courtesy of my NI Days mousepad from a couple years ago.mousepad.jpg
mohamedtanveej17
e,c,a,b,d
and i need to know what is the purpose of 5th one?and when will i use the 2nd one?
SercoSteveB
Hi mohamedtanveej17.  The last one allows you to switch between run mode and edit mode.  Switch to run mode when you want to see what your UI will look like at run time.   End Text entry allows you to end text entry, for example if you are commenting on your block diagram or adding text to a String Control you can use this shortcut when you are finished.  You can also use the mouse and click outside the bounds of the item you are editing, I guess it is down to personnal preference.
SercoSteveB
Hi MrStevenUND, nice mouse mat.  I have that one as well.
SercoSteveB
Answers: 1-e, 2-c, 3-a, 4-b, 5-d.  Nice one all.
