The Daily CLAD
Community Browser
Re: It's a Sign
SercoSteveB
What is Numeric Array Out following execution of the VI?
Comments
ersmt444
a
After a long time.. 🙂
nik35324
A
alexderjuengere
a
Matt-A.
A
crossrulz
Knight of NI
A
GCentral
karthick@krishnan
A
MrStevenUND
A
greggsavard
a
Gregg Savard
Certified LabVIEW Developer
DaleR
A
Tsjabrantes
C...
–1, 0, 1 returns 1 if the input value is greater than 0, returns 0 if the input value is equal to 0, and returns –1 if the input value is less than 0.
Tarciso Junior
+55 (11) 996-282-103
Skype: Tarciso.junior2
Email: Tsjabrantes@gmail.com
http://br.linkedin.com/pub/tarciso-junior/23/a83/463
SercoSteveB
Answer: A.  Nice one all.
Can anybody help me out here and has a use case for using the Sign node rather than LT 0 and/or LE 0 to identify the sign of a double.   I my mind this node should be called something like Change Magnitude to 1.
crossrulz
Knight of NI
I think I have only used this function in conjunction with a Subtract in order to figure out if X was >, <, or = to Y.  It was easier than doing all of the logic and manipulating that somehow to use with a case structure.
GCentral
levonsg
A
https://images.youracclaim.com/size/340x340/images/2edb5b1a-9414-44e1-8519-c774fc6dd079/36015_Certificate_Badges_FINAL__1__NI_Instructor_v5.png
