There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
Even generic probe cannot be used to all the data types. There is no such a choice for string array and queue out when I tried. But since the question is "multiple data types", not "all data types", I will choose "TRUE".
I am pretty sure that "generic probe" is just pointing back to the default probe.
Not a particularly well written question this one. What I was trying to say is that a Custom Probe has a defined input data type. If you right click on a wire to select a Custom Probe, only Custom Probes with the correct data type show up in the right click shortcut menu.
Hi Mohamed_Hany, can create a Custom Probe with a right click on the wire you want to probe and then by following the right click menu structure as shown below.
