Hey GY,
How much current and at what voltage will the Keithley 2636 be sinking? The 2636 can handle up to 10A/200V, but if you're not using that much current/voltage in your testing, we can look at some higher density relays. Until we know more, I'll throw out the:
PXI-2566, 16 SPDT relays with 5A carry/150V
PXI-2570, 40 SPDT relays with 1A carry/100V
If you need a higher current/voltage than this, post up and I'll show you some more niche solutions.
If you haven't already purchased the Keithley 2636, might I recommend an NI supply? The PXI-4132, the PXIe-4141, and PXIe-4154 might be a better solution if testing for speed is a deliverable. Throw the switch and the NI power supply into a small PXIe chassis, connect it to your computer using a high-speed PCIe MXI link and you've got one awesome test system. If you're already rocking the Keithley, you can connect it to a LabVIEW-based test solution with a USB-GPIB adapter, etc.
Let us know more about what you'd like to happen and we can dig deeper.
-John Sullivan
Problem Solver
