06-29-2016 01:19 PM
I got this Error when I wanted to run my system as usual:
"Error - 50152 occurred at DAQmx Switch Set Topology and Reset. vi:1. Possible Reasons: NI Platform services: A hardware failure has occurred. The operation could not be completed as specified. Device: PXIISlot3"
I have a NI PXI-1033 CHAISSE, with PIX-4065 and PXI-2575.
Both PIX-4065 and PXI-2575 can be found under "my system".
PXI-2575 passed self-test, PIX-4065 did not. When proceed to test panel for PIX-4065, receive "Error-1074117756. Possible reasons: Internal hardware error."
The system worked well before.I recently connected some resistor boxes in the outer circuit channels. Don't know what caused this problem. I have attached three pictures here for reference. Any advice is greatly appreciated.
Iris
06-30-2016 04:45 PM
Iris,
Sounds like something might be broken on the board based on the error message you see. Maybe the external circuitry exceeded some value. Can you try the 4065 in a different slot of the PXI chassis?
Kind Regards,
07-06-2016 10:36 PM
Hi Andrew,
Thank you a lot for the reply. I actually found the problem before I saw your suggestion:
I found that I got the same error code even when I turned off the PXI machine, so I restarted my computer twice and the error code is gone. Later the computer had an abnormal shut down, the error code appeared again when I started the computer. However, after I restarted the computer normally, the code disappeared. It seems that the error code appear everytime after the computer had an abnormal shut down. I hope this information will be helpful.
Iris
