Jorge,
I would agree that certainly a switch of some kind should be employed to control the machine's power. If turning it on and off by either applying or removing current is the only way to control it, then likely the best option would be to use an external relay controlled digitally by either a PC, PXI system, or programmable automation controller (e.g. FieldPoint). When all parameters are within limits, the digital line would remain high, thus closing the relay and allowing current to flow. However, once something goes wrong (rotation or vibration out of limits), the digital line would go low and disconnect the switch.
As far as a choice of platform, do you already have some equipment monitoring the machine -- or are you starting from scratch?
Alan L
Applications Engineer
