Switch Hardware and Software
Wiring to the pxi-2527 without tb-2627
We have used the TB-2627 to help development using PXI-2527 switch.  We are finished development and want to get rid of the TB-2627 because it protrudes so far out from the PXI chassis.  We want to wire directly to a connector that will plug into the 2527 switch and can secure to the 2527 switch.  I am looking for a connector that lends itself easily to solder connection and has a strain relief back shell.
The accessory plug recommended on the NI web site is an AMP brand, part number 533285-1.  This connector appears to be a PCB mount connector and not for individual wire solder connections or does it lend itself to strain relief.
Can you provide assistance?
David
(6,744 Views)
David,
The only think we could find is mating connectors from this link. They are still PCB mount but vertical instead of right angle.
Guy Ferraro
Switch Product Support Engineer
NI - USA
(6,739 Views)
