I need to control an RF latching relay (Agilent 8768M) with a PXI-2567. The relay coil requires either 15V at 188ma or 5V ar 325ma (a 24V, 125ma version is also available). I assume I can use an external 15V supply with the PXI-2567 drivers to control the relay but do I need to de-rate the current capability of the PXI-2567? I would like to control at lease two relays with each driver channel. Four would be great but that's either 752ma at 15V which is over the 600ma spec of the PXI-2567, or 500ma ar 24V.
Bob
