04-06-2017 06:29 AM
Hello
were are using the following route group structure:
SCI1Mod10 and SC1Mod11 are two SCXI-1191 RF-Multiplexer modules.
If I connect the route PR4G_ANT_9 using that panel all is fine. But if I connect this route using the route groups Signals_ALA9 or ALA_A_9 the path on PR4G_ANT_9 remains open ( both relays used in the path are in default/"open"/"disconnect" state). But there are no error messages as you can see in the attached debug panel log ( routegroup_debug.log, for comparison also route_debug.log from switching only PRG4_ANT_9). You see the problem only if you measure the RF paths with a networkanalyzer. An to make the problem even more strange : When using the switch from our teststand sequence , which uses the ALA_A_9 routegroup , we don't see that problem . There are no failed measurements due to a open RF path.
Are the any ideas what happens here: Software bug in Switchexecutive-3.6, hardwareproblem in SCXI-1001 chassis, in one of the SCXI-1191 modules oder a problem with the USB-1359 controller ?
04-06-2017 09:37 AM
Can you give the detailed route specification for each item in Signals_ALA9? Are there any exclusions or hardwires?
AKA:
ALA_3V3_9 = Dev1/Ch0A->Dev1/ComA
etc
04-07-2017 02:09 AM
Sorry , I've appended the wrong file as route group_debug.log.
The whole setup is a logical 16:1 Multiplexer. 2x 16:1x4 signal lines with the two 1127 cards SC1Mod1 and SC1Mod2. 3 "high current" 16:1 multiplexers channels build with 6 1161 cards (SC1Mod3-SC1Mod8) and 2 RF 16:1 Multiplexers channels build with 3 1190 cards ( SC1Mod 9-11). There are hardwires to build the 16:1 Multiplexers with the 1161 cards.
The RF multiplexers are build with one RF relay as root on SC1Mod10 and 4 hardwires on the roots 4 outputs to the 4 COM connectors of another 1161 module (SC1Mod9 for the ALA_ANT_x paths, SC1Mod11 for the PRG4_ANT_x paths)
In error case it seems that the root relay of the PRG4_ANT Multiplexer doesn't switch to the expected position. But I have no idea why, because it switches allways when switching the PRG4_ANT_9 route or using the ALA_A_9 routegroup from Teststand . If I will see one fail in that cases I would say "defective relay" but so far I can't.
04-07-2017 09:10 AM
All,
Sorry for the confusion, the txt file you send does not show the endpoint connections, which I need to understand the connections.
Can you send me the export of the virtual device?
http://zone.ni.com/reference/en-XX/help/370404J-01/nise/maxexport/ (txt or excel is fine)
04-09-2017 11:55 PM
Export file attached
