11-13-2005 10:07 PM
11-14-2005 03:56 PM
Hello Mike,
What kind of switch module are you using? I just simulated a PXI-2532 matrix switch on my system and created a route group which consists of 8 routes. These routes connect r0 to c0 - c7. When I connect that route group from LabVIEW, I can observe the connections that are made with the PXI-2532 test panel.
11-14-2005 07:03 PM
Hi Sean,
Thanks for your reply which has led me to a solution.
I am also using the PXI 2532. The trick is therefore to use a row as an endpoint and a column as another. However this cannot be done if you have already specified all your rows as Reserved for Routing and need them as such. I had to export the SE virtual device and then create another using it and edit it accordingly, and then create all the individual row to column routes for inclusion in route groups etc.. Yuk! Not only was it a lot of clicking and scrolling but it then meant I have my switching information and configuration spread over more than one file. Oh well, it works.
Also, my SE interface is very sluggish i.e slow response when scrolling and editing in the MAX. Is that normal? I am using a PXI8184 processor (850MHz celeron with 256mb)
Many thanks
Mike
11-15-2005 11:46 AM
Hello Mike,
My Switch Executive does not seem to be slow. Do you have other applications open at the same time? A large number of switch configurations?
11-15-2005 11:50 AM
Also, what version of Switch Executive are you using?
