10-17-2011 02:53 PM
I would like to make sure on the proper physical set up I should make to enable the BNC-2110 to function like it is in NRSE mode. We will be using an executable of labview, so we can not go in and change the code to function in Diff mode like the BNC-2110 is set up for, so we must set up the hardware to function as NRSE. If you could plese expalin this better that would be greatly appreciated. Thank you very much
Jason
10-18-2011 05:02 PM
Jason,
Did you see the solution posted here to your previous question?
I think this AE has already provided you with what you are looking for.
Daniel
