NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
David Ng
SCXI 1127 4-wire software setup
Hi All
I experienced a problem to connect channel ab0 and ab2 to the respective measurement channel so that I can get a resistance reading. I'm using SCXI-1127 with 1331 and a DMM of HP34401A.
I have done my wiring correctly and now it's a matter of coding it correctly. There are lots of way to do this in my mind. Tried each one of them and didn't work.
Any help (software or detail of coding sequence) will be very much appreciated.
David Ng
Member
Guy Ferraro
Re: SCXI 1127 4-wire software setup
What is controlling the SCXI-Chassis?
What version of NI-SWITCH do you have?
Member
David Ng
I have Labview 7.1 which means I'll have the most updated Ni-switch. A 421 PCI card is controlling my chassis either through traditional Ni-DAQ or Ni-DAQmx.
My computer has the following:
1. 488.2 GPIB controller
2. PXI - not related for this particular problem
3. NI 421 PCI card
4. SCXI - 1000 chassis
5. SCXI - 1127 Mechanical relay switch that will need to be set up in 16x1 4-wire mux
6. SCXI - 1331 module
Thanks for following up so fast
Dave
Member
Guy Ferraro
- Use the chassis created in DAQmx.
- In MAX (SCXI-1127 property) select the SCXI-1331 as the terminal block for the SCXI-1127.
- Use the shiping NI-SWITCH example found in: F:\Program Files\National Instruments\LabVIEW 7.1\examples\instr\niSwitch called niSwitch Making Connection on a Switch.vi.
- Delete the second connect vi and wait for debounce
- Point to your SCXI-1127 (SC1Mod4 for example)
- Change the topology to "1127/4-Wire 16x1 Mux"
- Check the NI-SWITCH help file (Start>>Programs>>National Instruments>>NI-SWITCH>>Documentation>>NI Switches help) for valid channel names under: NI Switch Help>>Devices>>SCXI-1127/1128>>4-wire 16x1 Topology
Member
Guy Ferraro
Correction: your NI-SWITCH examples should be in the root directory.
Member
David Ng
thanks
Your suggestion really helps a lot!
Dave
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
