I am still scratching my head as to why trying to find the connection
status of a PXI rf switch card is so difficult, and there is no simple
call to make.
Having said that, I am already using DAQmxSwitchFindPath() to correctly
determine the status of my 4x1 pxi 2591 card. It takes four seperate calls to test each path, but it works.
However, when I use the
same technique for my dual 2x1 2599 card, it will not report the
correct state for both switches - only the one that I last set. In
other words it reports that the other one that I set previously is
disconnected. Yet, these are two independant switches.
I would really like to know if:
a) this is a bug with the daqmx system or driver (daqmx 7.5.0f2)
b) there is a better way to determine the current switch state for these cards
Very puzzled. If I were a developer, the very fist software call I
would have implemented would have been to return the switch states!
Any help appreciated!
Cheers,
Avner Ginsburg
aginsburg@kleer.com
