09-14-2015 02:22 PM
Can all (or multiple) switches in one bank be turned on simultaneously? As shown below
Solved! Go to Solution.
09-14-2015 02:36 PM - edited 09-14-2015 03:05 PM
<Edited Response - See Post Below>
09-14-2015 02:42 PM
Thanks!
I was trying to find a solution with our existing hardware.
I am trying to do an automatic open/short test on an IC and need to cycle through the 48 pins one by one, while the other 47 pins are connected to GND.
09-14-2015 03:05 PM
After talking with a few colleagues, I was reminded that there is a way to make it work with your existing hardware. If you use the NI-SWITCH driver, there are a set of individual relay control functions that will allow you to connect multiple inputs within the same multiplexer. However, this method will have a more complex code implementation, since you will need to control each individual relay manually. Here is an example that uses a for loop to close every relay on the 2576.
Sorry for the confusion!
09-14-2015 03:08 PM
This is perfect! Thank you so much Mike!
