NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
wessyn
PXI-2567 cable
Hi
I received PXI-2567 module with only one connector without a cable. How can I get the cable?
Member
Frank-L
Re: PXI-2567 cable
Wessyn,
As outlined in How to Connect Signals to the PXI-2567, we provide a 78 pin DSUB connector and backshell kit for customers to create custom connectivity solutions for these modules. Many customer would use these to create their own cables or connectivity by soldering the connector to a cable or PCB. If you are interested in using a cable solution, it is not very difficult to find these solutions externally. Since this module is using a standard 78 pin DSUB connector, a quick internet search of "DSUB 78 Cables" reveals many external options for cables and connectivity.
As always, verify that the cabling setup that you do select can handle the voltage and current levels that your application requires. Additionally, you must install connectivity solutions according to local safety codes and standards and according to the specifications provided by the cable manufacturer.
Let me know if this did not answer your question!
Frank,
Switch Product Support Engineer
Active Participant
Now_With_Underscores
Re: PXI-2567 cable
Hey Wessyn,
FYI: The 2567 is a DIY module; NI provides the driver, you add your own relays, possible make your own PCB, and then figure out your application's optimal connectivity option.
If you are looking for a finished cable solution, Virginia panel sells at least four unique 2567 cabling solutions.  Check out their 'configurator':
http://www.vpc.com/wire_plus/configurator/
Apologies our presales channel did not clearly state the items you'd receive with the 2567.  We definitely value user experience feedback and are always open to any suggestions.
Have a wonderful everything.
-John S
Analog Engineer
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
