Switch Hardware and Software
PXI-2527 Is Not detected as DAQ device in NI-MAX
I have PXI-2527 in my Chassis and NI-MAX is not detecting it as a DAQ device.
rather it is deected only as a normal PXI device listed.
what could be the possible cause for this?
Thanks in Advance
Bharathi
(5,882 Views)
2527 is not a daq device. It is a switch, It is correct if it is being dispalyed as a module in one of your PXI slots in MAX.
(5,873 Views)
While the PXI-2527 is not a DAC or ADC device, it is supported by the NI-DAQmx driver.  If you need help programming the switch in NI-DAQmx, open C:\Program Files\National Instruments\LabVIEW X.Y\examples\DAQmx\Switches\Switch.llb
The NI-Switch driver is a bit more intuitive, so I'd recommend installing it if you're just getting started.  Once installed, the NI-Switch examples are here: C:\Program Files\National Instruments\LabVIEW X.Y\examples\instr\niSwitch
Switch.llb
-John Sullivan
Problem Solver
(5,865 Views)
