NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
RichM
MAX Generated Switch Executive XML configuration file conflicts?
I have distributed a Switch Executive XML configuration file to my test stations using MAX 2.2 (the XML header in the file says "MAX version = 220", but they are now using MAX 3.1 - will this cause a problem? It already seems to take an eternity to load when calling niSE_ImportConfiguration() - (from niSE.dll)
Member
Guy Ferraro
Re: MAX Generated Switch Executive XML configuration file conflicts?
You should not have any problem importing in MAX 3.1 a NISE configuration xml file created under MAx 2.2
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
