01-10-2012 07:39 AM
We using NI-2529 to connect our Sources and Multimeter's with DUT.
Most of our tests starts with configuration Matrix and then all other equipment. Its simple in LV, disconnect all then connect needed.
Now I want to know what are relays close and then reconnect if needed using LV? I can see what relays connecting in NI-SWITCH Soft Front Panel, but how to get the same in LV ?
01-10-2012 02:01 PM
Hey Denis "Equipment" KM,
If you're using the DAQmx API:
If you're using the NI-Switch API:
Have a wonderful everything!
01-10-2012 11:50 PM
thanks
it's a simple and good example
