I'm trying to program a SCXI-1161 switch module using the NI SWITCH relay subpallet in Labview ("niSwitch Relay Control.vi", "niSwitch Get Relay Position.vi", and "niSwitch Get Relay Count.vi"). My application initializes the module using "niSwitch Initialize With Topology.vi" and then calls one of the 3 Relay vi's listed above. It doesn't matter which one is called, I get the same error everytime - "Invalid Parameter". Since the only input parameter aside from the error cluster and Instrument handle is relay name, I'm guessing this is the parameter that Labview is choking on. How do I set a relay name or determine what the relay name is, or have I misdiagnosed the problem?
