Hi Abdula,
It sounds like there is confusion regarding the deployments for NI Switch Executive(NISE). Hopefully I can answer some of your questions.
The licensing for NISE is on a per computer basis and there are 2 different types of license: development & deployment. The development license is used on your development machine. This allows you to create, edit, manage, export NI Switch Executive Virtual Devices which are essentially configurations of your switching system. The exported configuration is in XML format but it requires the NISE engine to correctly interpret it. Therefore whatever computer you run it on will also need either development or deployment software installed. The deployment can only import that configuration and run it. That being said, if you want your switch program using NI Switch Executive to work on another machine, you will need the following:
1) Development or deployment software
2) NI Switch Executive Virtual Device (XML file)
3) IVI Configuration File (XML file)
If you bought a single development license, you have rigths on 1 machine total. If you have 2 machines, you will need 2 license (either development or deployment depending on what you need to do in NISE).
Anyway, I hope that clears some of the confusion. Please contact me if you have any other questions.
Ron
Ron Harrison
Product Marketing Manager
