Switch Hardware and Software
Hardware advice for photodiode array read-out
Hello everyone,
I have a photodiode array with 35 pixels. I want to record sequentially the signals coming from the 35 pixels. I would therefore need to multiplex these 35 signals to 1. Can somebody give me some advice on the hardware to use in order to realise this operation?
I have a DAQPad 6052E and a BNC-2090 to perform data acquisition. Unfortunately I don't have enough channels to record the 35 signals one after another.
Any advice would be greatly appreciated,
(6,700 Views)
What are specifications of your photodiode signal ?
I think you need a switch matrix instead of DAQ device. Have a look to this web page : http://www.ni.com/switches/
Isabelle
Ingénieur d'applications
National Instruments France
(6,680 Views)
Thanks for your response.
Photodiode signal is a DC negative voltage (less than 5V). A multiplexer (or matrix) module seems indeed of interest. If I am right I would therefore need a chassis (PXI or SCXI) along with a multiplexer module and a screw terminal block (to connect the 35 signals)? Can I connect a multiplexer module to the DAQPad-6052E for data acquisition?
(6,675 Views)
