Switch Hardware and Software
Connecting two 1-wire channels to a 2-Wire channel in Switch Executive
I have a custom IVI 24x16 matrix and will be using the channels in groups of 2 and 4.  I would like to connect these 2 and 4-wire signals to the AB0 and AB1 inputs of a PXI-2503 multiplexer.  In Switch Executive all the signals of my matrix are characterized as 1-wire, but the PXI-2503 multiplexer inputs are characterized as 2 and 4-wire when in those respective modes. I can't figure out how to configure these as hardwires or buses so that Switch Executive will allow me to select one endpoint as the matrix and one as the multiplexer output.
-Andy
(6,866 Views)
Andy,
At this time, Switch Executive does not have support for creating routes that span channels with different wire modes. As a work around, you could create routes for individual legs of a route that have uniform wire mode, and then group them into route groups. This way you will lose some of the auto-routing otherwise available to you when you have uniform wire mode, but you will still have the flexibility of having named routes in your application.
I hope this helps,
-Serge
(6,861 Views)
Andy,
To add to Zrdan comments, I would like to suggest this Knowledge Base entry:
 Can Switch Executive Connect One Row of a 2-Wire Matrix to Two Different Channels of a 1-Wire Switc...
There are a couple work arounds.
Guy Ferraro
Switch Product Support Engineer
NI - USA
(6,854 Views)
