Switch Hardware and Software
Can you zoom in and out on the block diagram window?
My question is simple. Can you zoom in and out on the block diagram window?
Message 1 of 9
(47,371 Views)
Hi Champ065,
I've often found a simple question can result in an elaborate response.
The feature that may assist you is the Navigation window.  When the block diagram window is displayed, select View>>Navigation Window (Ctrl+Shift+N) and you'll be able to focus on your desired window-sized section of block diagram code.  In effect, this gives you the option of navigating a zoomed-out version of your VI's block diagram.  Is this what you're looking for?
If you're looking to zoom in on the actual pictures of your VIs, or want to view the entire block diagram on the screen and be able to interact/change the block diagram at the same time, then you may want to post this question on a LabVIEW forum, as the experts who monitor those posts may give you a better reply.
Hope this helps!
Chad Erickson
Switch Product Support Engineer
NI - USA
Message 2 of 9
(47,367 Views)
Thank you! That was helpful. I will also check in the LabView Forum, as well.
Message 3 of 9
(47,361 Views)
Hi champ065,
Another good discussion forum that addresses this question is here.
Message Edited by JamesR on 10-25-2007 01:08 PM
James R.
Message 4 of 9
(47,349 Views)
hi
i really need help but i cant speek english very well
can u help me in labview?
i have some questions...
tank u
my email:
zizou_arman@yahoo.com
Message 5 of 9
(44,016 Views)
hi
tank u
my email:
Message 6 of 9
(44,015 Views)
Hi abc_arz,
You can create a service request at ni.com/support. If you set the country on ni.com (in the top right corner) to where you live, you will find proper contact information for the National Instruments branch closest to you.
This will be the best way to get help with your LabVIEW questions.
Take care!
Tanya Visser
LabVIEW Group Manager
Message 7 of 9
(44,000 Views)
So far I havn't found a way to zoom in or out IN LV, however if you're using Windows 7 (if I recall correctly even in Vista) or later you could use the Magnifier (windows.microsoft.com/is-IS/windows7/Make-items-on-the-screen-appear-bigger-Magnifier) application wich lets you zoom in or out of a reasonable area around your pointer. Additionally it lets you work as usual so you can also modify your program while zooming in.
Message 8 of 9
(36,875 Views)
Message 9 of 9
(22,249 Views)
