Switch Hardware and Software
Can I close multiple output channels in parallel on one COM line using the PXI-2503
I want to fan out a power supply to four DUTS. During current testing, I will want to turn on one DUT at a time. During other tests, I want to power all four DUTS in parallel. This will require turning on four output channels at once in each mux bank. Can this be done using the PXI-2503?
(7,034 Views)
Yes, It is possible when you use the 24x1 Mux toplogy. Simply connect as many channels as you want to com0.
Guy Ferraro
Switch product Support Engineer
NI - USA
(7,026 Views)
I assume this is true in the 4x6 2-wire mode. This is how I would use the module with up to four channels connected to each COMx input.
Bob
(7,042 Views)
Bob,
4x6 2-wire mode should work fine. You can connect the power supply to one column, and the DUTs to each row. The rows can be connected to the column one at a time or all at once.
Jessica Kinnevan
Applications Engineering
(6,990 Views)
