06-19-2007 12:06 AM
06-19-2007 10:48 AM
Hi Tumbler,
I would like to ask a few follow-up questions:
I'm assuming you are using the NI Switch Executive Test Panel in MAX to close "Route0".
1. Is this a correct assumption?
2. Have you been able to successfully validate your routes and route groups (with the simulated option checked and unchecked)?
3. Are you simulating via IVI (this would be selected in your Driver Session) or are you toggling actual hardware states?
4. Which Agilent driver are you using? There is a generic Agilent driver and one specifically made for use with NI Switch Executive, as shown at the following link:
http://adn.tm.agilent.com/index.cgi?CONTENT_ID=2750
Thanks!
Chad Erickson
Switch Product Support Engineer
NI - USA
06-20-2007 12:26 AM
06-21-2007 09:26 AM
06-21-2007 11:56 PM
Yes I can.
Here please
06-26-2007 05:39 PM
06-26-2007 11:49 PM
Ok thank you Patrick
i will try it with USB. I have tried it with Labview and it still works too.
Thank you very much.
Best Reguards
Tumbler
06-27-2007 01:05 AM
09-19-2012 07:16 AM
Hello Tumbler,
I guess it's a bit TOO late for you but maybe someone else will have the same issue concering MAX.
You can add the 34980 into MAX even if it does not find it.
You go to Devices and interfaces -> network devices and you press "add network device".
Then you insert the IP of your 34980 and you will be able to communicate through MAX.
cheers
