Good afternoon 9845567540,
Thanks for contacting National Instruments with your issue, we'll try our best to resolve it for you as quickly and efficiently as possible.
You didn't mention which topology you require for your relay system, so I assume you want just a general purpose (non MUX non Matrix) relay.
Assuming you want to go with the PXI form factor I would take a look at the PXI-2566 if you want SPDT or PXI-2564 if you want SPST:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/12256
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14545
The current handling should not be an issue, but the breakdown voltage of 500 VRms might be of concern. We don't specify a breakdown voltage (depending on your interpretation of the term) but none of our general purpose devices are spec'd to switch more than 300 V.
Minh Tran
Applications Engineering
