Sound & Vibration Applications
Reply
Embedded High Speed Data Logger Reference Application
Highlighted
Please provide feedback, comments and questions on the Embedded High Speed Data Logger Reference Application in this thread.
Message 1 of 13
(6,271 Views)
Re: cRIO Reference Design for Vibration Data Logger
I am facing problem on the try to download the code. The hyperlink redirects me to a page where no sense of code exists.
Message 2 of 13
(5,194 Views)
The code is undergoing a minor revision, to update in support of the latest waveform reference design:  http://zone.ni.com/devzone/cda/epd/p/id/6206
Can you describe your need, perhaps we can get to you the needed code prior to the update completion.
Preston Johnson
Principal, Subject Matter Expert Condition Monitoring Systems
Allied Reliability Group
512 431 2371
johnsonp@alliedreliability.com
Message 3 of 13
(5,191 Views)
It would be kind of you to inform me as soon as you have the final version.
Thanks in advance.
Levon
Message 4 of 13
(5,186 Views)
Is the latest version available yet? The old version has been removed.
Message 5 of 13
(4,967 Views)
The latest version is located here:
http://zone.ni.com/devzone/cda/epd/p/id/6388
Please let us know what questions you have.
Preston Johnson
512 431 2371
Message 6 of 13
(4,784 Views)
Hi Preston Johnson
The download points to VIPM but there is no such toolkit available in VIPM.
Regards
D.Arunkumar
Thanks & Regards
D.Arunkumar
Founder & Chief Executive
Yashika Industries
3i, Vantage Plaza, #1 LB Road - MG Road Junction,
Thiruvanmiyur, Chennai - 600041
Mobile: +91 9840562844, Office:+91 4443532119, Mail: arun@yashikaa.in Web: www.yashikaa.in
Your technology partner for automation and test
Please DO NOT print this e-mail or attachment(s) unless it is absolutely necessary
Message 7 of 13
(4,515 Views)
look to the right on the page - there is a downloads box/section there with the VIPM and a document.
See the screenshot capture
Preston Johnson
512 431 2371
Message 8 of 13
(4,510 Views)
I try to use this example in a cRIO 9074 with a SAR module (I use the FPGA .vi in cRIO Waveform Library) and it does not work.
The CPU usage is mantained at 100%, some seconds after the program is running on cRIO.
Is there any problem known in this example that could be fixed, or its possible that i'm the responsible for the malfunction?
Message 9 of 13
(4,216 Views)
Is this going to be updated to LV 2014? Some of the VIs are broken.
Message 10 of 13
(3,273 Views)
