NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
milmuell
time averaging
Can somebody help me please with this problem? I am trying to perform time averaging from signal in Signal Express but the input and the output signals are the same. Attached is the printscreen of the process. Can somebody tell me what I am doing wrong?
Active Participant
Ardent
Re: time averaging
Hi milmuell,
let's take a look at your acquisition, so that we can work out what is the problem with the averaging.
What is your sampling rate? It might be possible, that averaging through 100 values is not enough to be seen in the graph. Could you perhaps log and post your measured data?
Jano
Trusted Enthusiast
DFGray
Re: time averaging
According to the screenshot, you have only run this once (iteration count is one).  You can set your run mode to execute 100 times or continuously, then run until the iteration counter hits 100 or more and you should be good to go.  If you have problems, post your project and we can take a look.
Using LabVIEW 2009 - 2012 on Windows 7 64-bit
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
