10-22-2013 04:20 PM
Hello:
I am using Signal Express with a USB-6009. The attached sensor is a flow meter 0-5VDC output, scaled 0-5V to 0-500SLPM.
When running the software with no scaling, there are no problems. When using custom scaling, whether linear or map ranges I get flatlined readings at about 1 V output or 100 SLPM scaled output.
Any suggestions? Thanks!
10-22-2013 05:26 PM - edited 10-22-2013 05:29 PM
how are you supplying power to the sensor?
what sensor type are you defining it as in Signal Express?
what are you entering for custom scaling values?
what's your min/max output range in the device settings tab?
attaching your project file may be most useful since the information you're giving is not very thorough.
