11-14-2008 08:01 AM
I've been having problems with the "project documentation" section of my Sound And Vibration Assistant (based on signal express). It's been locking up and corrupting previously good projects. When I add the peak search step to the documentation and hit "view as - cascade" everything seems to fail, the project locks up, is not responding, it doesn't even let it close, have to call task manager to close it, after that when I try to open again that same project, it doesn't even open fully and is locked up again. Any help with this would be apreciated.
11-17-2008 05:05 PM
F@SII,
I've got a couple of background questions for you:
11-18-2008 06:35 AM
Seth:
I was just analyzing one channel at the time.
The sound and vibration version we are using is 6.0.0.
Signal express ver 3.0.0.
It is a waterfall graph.
For some reason it also crashed when I was trying to resize one of the other displays that I had in project documentation.
Some time ago I also reported some problems with printing the Peaks display (Reference#7211104). Could this be related?
11-19-2008 01:54 PM
11-20-2008 09:00 AM
Hello Seth, I'm attaching a couple of files. The first one contains a screen shot of the steps that I'm using in the project, The second one is the message that I received when SAV assistant quit on me and the third one is the printout of project documentation before it started failing, the second to last graph is the one I think is creating most of the problems, when I removed that graph from project doc it worked fine, other than when I tried to resize one of the other graphs.
I'm gathering data from an accelerometer I take the time domain signal and transfer it to freq domain, zoom in on the power spectrum linear magnitude scale.
Let me know if you need any other info.
F@SII
11-25-2008 09:07 AM
F@SII,
I've tried a couple of ways to reproduce this problem on this end, but I'm not having much luck. What percentage of your computer's memory is in use before you modify the graph? Also, if I had a copy of your project, I would probably have more luck reproducing the crash. You can either post the project here or, with your permission, I could e-mail you and have you respond with the project attached. This will allow me to recreate your setup on a test machine with the actual project in hopes of triggering the crash.
11-25-2008 09:20 AM
