SignalExpress
signal express installed in german language !
Dear All,
I am working in Germany. I downloaded Signal Express 2.5 and when I install it, it installs the german version and does not give any option to install in English. My operating system
is Windows and is also in English. Any ideas?
sincerely,
Munir.
Message 1 of 8
(6,918 Views)
I'm not sure if this will solve your problem but I would try to set the keyboard langage to English before installing the software. If this should not work, another attempt would be to change the regional settings in the control panel.
Message 2 of 8
(6,916 Views)
perfect answer thanks, i chabged the regional settings.
Message 3 of 8
(6,914 Views)
I had the same issue some years ago with DAQ.
Message 4 of 8
(6,909 Views)
LabVEIW SignalExpress looks at the regional settings in Windows to determine the appropriate language.  Changing the settings to english will change the software for you, no reinstall is needed
Message 5 of 8
(6,903 Views)
We have 2015 ..
Is this still the way it works?
SignalExpress is starting in the language defined by the regional setting?
Although all my software - including windows - is running in english, I need my regional settings to be set on sg (swiss german).
This is mandatory, since this is used by a lot of software for formatting of date, time, currency, etc. Also the timezone and daytime savings depend on that, etc.
There must me a different solution!
Thanx in advance!
-Didix
Message 6 of 8
(4,493 Views)
Did anybody find out, which registry setting SE is reading for the decision?
-Didix
Message 7 of 8
(4,486 Views)
Now I created two reg files on my desktop:
File 1: _reg_SetLocaleName_en-US.reg
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Control Panel\International]
"LocaleName"="en-US"
File 2: the analog file that sets the LocaleName to the original LocalName of my machine.
Doubleclick File 1, start the required NI Program (eg SE). When the program has started in english, I doubleclick the reg file 2 and the locals settings are as original 🙂
Works perfect 4me.
Disclaimer: tampering with the registry is everybodys own risk ...
-Didix
Message 8 of 8
(4,483 Views)
