05-17-2012 03:46 AM
hi,
weel, i have a problem with signalexpress, i want to executate some labview vi in it, but there is one that only it must executate only once, but always in signal express appear the while loop when i choose run labview...VI,
so my questionis what i must do to executate only once one vi??
and no using the tool of running once the program?
thanks
Solved! Go to Solution.
05-17-2012 06:06 AM
also someone knows how to record different signals in only one tdms, because if i have two diferent outputs, the program record one tdms for each output and only i want one for all the project
THANKS!
06-04-2012 06:23 AM
Hi, alan,
there's no way to remove the way loop from the Run LabVIEW VI Step. The only way to achieve this is running once the SE code. I am afraid this funtionality is not implemented in Signal Express. Since SE is a configurable environment there is no flexibility at all. The only thing you can do is using LabVIEW. You can convert you SE project to LabVIEW code via >> Tools >> Generate Code >> LabVIEW Diagram. Once in LabVIEW you will modify your code so as to execute only one time a part of it.
The same issue occurs when logging data in a TDMS file: it will generate a file per variable you want to log.
Conclusion: extent SE functionality in LabVIEW.
I hope this helps!!
Jesús
06-04-2012 06:24 AM
I meant:
there's no way to remove the while loop from the Run LabVIEW VI Step.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
