10-04-2009 01:08 AM
i only recently started using signal express...
i want to be able to change the sampling rate so i can specify how many data points should be recorded per second...
i know that chagning the 'sampling rate' in the 'step setup ------>configuration' window should do what i want...
however, after havng recorded adn transferred the data to an excel sheet... the dt is always equal to 620u...
somehow, changing the 'sampling rate' has no effect on the final set of data recorded on the excel sheet
regards,
Saara
10-05-2009 04:52 AM
11-10-2009 07:11 AM
I have got a similar question:
I am using SignalExpress for logging data from a fermentation.
So I do not need high sampling rates. It is enough when SE saves every 2 minutes a sample.
But my questions is: Is it possible to set different sampling rates for loging in the protocol on one hand and for displaying the data on the other hand?
Br
11-10-2009 07:44 PM
