11-25-2008 10:31 AM
I don't manage to generate a signal at the analog output with my vi "generate waveform". I use the NI USB-6008. It tells me that the error code is 200077.
Also I don't manage to generate a signal with signal express. it tells me the same error message "error 200077".
Thanks in advance for your help.
11-26-2008 07:11 AM
Tout d'abord, si vous le souhaitez, vous pouvez écrire en français.
I have manage to make your VI "Generate Waveform.vi" work correctly with a USB 6009.
Have you correctly selected an analog output of your 6008 on the "Physical Channel 2" control on the front panel of your VI?
I suggest that you open "Measurement and Automation" (MAX) software and check that you can see your 6008 under "devices and interfaces".
Then, open the "test panel" for your 6008 and check that you can perform an analog output.
If it works with MAX, it should work with your VI.
11-26-2008 10:41 AM
Bonjour,
Mon problème venait du fait (si j'ai bien compris) que ne peut pas donner un signal continu en analogique. Ce lien m'a aidé aussi:
http://digital.ni.com/public.nsf/allkb/6F2C2B49A89D685C8625711D007BDD64
Merci pour votre aide
Nicolas
