NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
AkshayHari
Using SE as a Controller
Is it possible to use SignalExpress to automate the repitition of the following task...
1) Record a voltage for 30 seconds using an NI DAQ
2) Send a digital output immediately following the 30 seconds to open/close an air valve for the next 5 minutes
I would like to be able to repeat the above two steps over the course of a few hours.
Akshay
Trusted Enthusiast
DFGray
Re: Using SE as a Controller
Yes, provided you don't need really tight timing.  If you do, you may still be able to do it by chaining triggers through your acquisition and generation devices.  Look at the sequence break step and the digital triggering options for your devices.  If you need more info, let us know and give us a bit more information about what devices you are using.
Using LabVIEW 2009 - 2012 on Windows 7 64-bit
Member
AkshayHari
Thanks a lot for your reply.
Will play around with what you mentioned and let you know if I need more info.
Best,
Akshay
Member
AkshayHari
I am using an NI USB-6210 DAQ. I have not finalized on a controllable air valve yet, but found one that takes 4-20 mA input as its control signal.
Any other tips?
Akshay
Trusted Enthusiast
DFGray
The 6210 only has digital output, so you will need an external circuit to switch the 4-20mA control for that valve.  This could be as simple as a battery-resistor-transistor or as complex as an off-the-shelf commercial unit (if you are careful, you can use the 5V output of the 6210 as the battery).
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
