08-17-2009 06:51 PM
We are using a NI PCI-6115 to generate two output waveforms that will be used to operate a scanner. I thought it would be easy to use SignalExpress to do this; however, our waveforms are user-defined (not generic like sine or sawtooth). Below is an image of how we would like our waveform to look like. Going up, we would like 512 points; going down, we would like 100 points. We would also like to have the option to select the duration of time between each point, and also be able to limit the maximum and minimum voltages for our waveform. Thanks, I appreciate any help you can offer!
08-18-2009 08:29 AM
Unfortunately, SignalExpress does not natively support this waveform type (please submit a product suggestion here!). You have several options:
