05-02-2012 12:00 AM
Foremost I will like to highlight that I am very new to Labview (using Labview 2011) and Sound and Vibration Assistant (Labview Signal Express 2011). I am embarking on a project to measure speech (sound pressure using microphone) and body vibration (using accelerometer) connected to NI 9234 DAQ. I have looked into the tutorial and examples provided together with Sound and Vibration Assistant (SVA). Those examples allowed me to make a recording first which is logged. I could visualized the playback display once I transfer the log file to the data view. Frankly I am more assured of my measurement data if I could observe the timewave variation with speech. I wonder if this is possible. If it is possible, thanks in advance for pointing out the direction.
Thank you.
Abu Dzarr
Solved! Go to Solution.
05-02-2012 07:59 AM
You can watch the data as it accumulates in one of two ways:
03-14-2015 12:29 AM
i want to programme speech signal write on file and again it will be read how to dothat please tell me
03-14-2015 01:36 AM
You posted in a two year old thread that is already marked as solved.
Since you posted in the signalexpress forum, I assume you are using SignalExpress. Is this correct?
I strongly suggest that you start a new thread and provide singificantly more detail about your hardware and software setup. Good luck.
