01-09-2009 06:57 AM
I searched in the NI forums, and I found some threads saying that LabVIEW works on a XP Tablet PC Edition.
But what about SignalExpress?
I installed SignalExpress 2.0 over my Tablet PC (Samsung Q1), but when I try to launch the program I can see the splash screen, but then there is the following popup message:
Initialization Error
LabVIEW SignalExpress is not installed.
Please install LabVIEW SignalExpress before running the application.
Can anybody help me?
Tks
Solved! Go to Solution.
01-12-2009 04:16 AM
Hello Vix,
I suppose there aren't differences between LabVIEW and Signal Express Compatibility on your Samsung Q1. Did you already perform a repair of the Signal Express installation? You can also try to upgrade your software at least to the 2.5.1 version so you could fix your problem.
01-13-2009 02:05 AM
I'm sorry, but I don't understand what do you mean with this sentence. Could you explain it?
Yes, but it didn't help
I know I could try, but I'm not interested in it. I can activate a full licence of 2.0 version because I bought a LabVIEW 8.2 Full Development System, but I have to pay if I want a full licence of SignalExpress 2.5. I asked to a NI vendor, and he told me SignalExpress upgrade is not possible for free. Could you confirm this?
Tks
01-13-2009 04:20 AM
Hi Vix,
I mean that both LabVIEW 8.2.1 and Signal Express 2.0 would be supported on Microsoft Windows Tablet Editions. Could you report exactly the software you installed on your Samsung Q1? Did you perform the licensing procedure correctly? According to the error you attached, it seemed that something wrong occurred during the software installation. Anyway you could download the latest Signal Express version (3.0), install it in evaluation mode and verify if you could reproduce the same warning.
Please let me known how it works.
Regards
01-14-2009 06:36 AM
I had to update all NI drivers and components using the DAQmx 8.6 CDs instead of the DAQmx 8.5 ones (supplied with LabVIEW 8.2.1).
I didn't install the SignalExpress 2.5 from this CDs, so I'm able to use the 2.0.
