06-10-2015 08:10 AM
I have an acceleration signal and I want to convert to velocitty and displacement.
I tried to use a VI, posted in the link (https://decibel.ni.com/content/docs/DOC-12714) but it didn't work. When I select the VI, it seens there is no VI selected, see the image attached.
My signal express suport Labview versions 2011, 2012, 2013 and 2014 (32 bits).
Am I doing the right thing to use the VI in signal express? Is there any other way to integrate my signal using Signal Express (I don't have Lab View License)...
I really appreciate any help.
Best regards
José Guilherme
06-11-2015 07:39 AM
For you use Run LabVIEW VI step you must have the corresponding version of the LabVIEW Run-Time Engine installed. If not Signal Express can not execute it.
Further information you can check at:
http://zone.ni.com/reference/en-XX/help/371268K-01/expresswb/run_lv_vi_pal/
Link bellow you can download LabVIEW Runtime Engine 2009 for only use Run LabVIEW VI step in Signal Express.
http://www.ni.com/download/labview-run-time-engine-2009-sp1/1600/en/
And if you want to customize/modify from an existing Run LabVIEW VI step you need LabVIEW Development System installed.
