I'm using Signal Express and would like to acquire data at a sub 1kHz rate. Doing that I get error code -201001, suggesting that I need to set the Enhance Alias Rejection Enable to value True for the 4472 boards I'm using. Searching this problem I found how to do that in LabView, but nothing for signal express. I have a separate metrology system that I'm trying to synch the Signal Express data with that is limited to sample at 100 Hz.
What is the best way to collect data at a sub 1kHz rate?
Thanks for any help.
