SignalExpress
Relay Chatter software
I am looking for a program that can be ran after testing using Signal Express has collected the data.  I need to be able to create a chart showing relay chatter quantity for various different ms readings and voltage tolerance levels.  Is there anything that is common software or for sale that can help me with this?  Thanks
(3,654 Views)
Cant you save to ASCII and create a chart in Excel?
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(3,629 Views)
I am currently trying that but I was looking for software that has already been written that is capable of reading 16 contacts and up to 500 chatter points.  This is being used for seismic testing and there is a good amount of chatter to count and measure time across per chatter.
(3,616 Views)
To clarify, are you looking for software that is taking your data measurements, or processing and visualizing the measurements that you've already had?
(3,604 Views)
