SignalExpress
Moving projects from 2014 to 2015
I'm trying to move a project created in SE2014 on one PC to SE2015 on another PC.  I've copied the .seproj file across and opened it.  It looks OK, except that all the custom scaling I've been using are missing.  Is this a known issue or have a I missed something else that I should have transferred?
Thank you for any suggestions you can make.
Paul
(3,988 Views)
Accepted by topic author EngineerPaul
You need to import/export your scales over.
Open NI MAX (measurement and automation explorer) and click file>export... click next and select your scales, then Export. You can get to MAX from the Tools menu within SE as well.
Once  you have that .NCE file you can transfer it to your new PC. Double click it and you'll go through the same wizard but in reverse.
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(3,972 Views)
Thank you OKors - I hadn't realised they were stored there rather than in the SE project.
(3,950 Views)
