03-19-2009 03:22 PM
03-19-2009 03:41 PM
It sounds like your two different PC's have different versions of NI-DAQmx. The one that you create the project file on sounds like it has a newer version than the one you are trying to load on.
The "DAQ Assistant components" is the DAQ step you used in SignalExpress, which gets installed with NI-DAQmx.
Phil
