03-21-2009 11:05 PM
Is the sampling rate, 16384 Hz a special number for Signal Express or BNC 2110 and NI USB-6251?
The following are my test setup.
Generated Signal: Sine wave
Frequency: 200Hz
Sampling Rate: 16384Hz
Block size: 4096
The output channel is connected to two input channels directly. And power spectrum steps and frequency response steps are used to get phase, magnitude, amplitude and coherence. At this specific sampling rate, the coherence is a mess and different from what I got other tests using other signal analyzer. I am wondering what's the reason.
And the frequency steps in the power spectrum are always different what they are supposed to be, which have frequency shifts. Thank you.
03-23-2009 12:50 PM
03-23-2009 02:40 PM
Hi Doug,
Thank you for your reply.
It's a small region around 16384 Hz. When the sampling rate was changed to 17 kHz, 15kHz or other values, I got perfect coherence, phase and magnitude.
03-24-2009 04:54 PM
04-02-2009 03:34 PM
Doug,
I did the test for several times and got the same results. Did you find anything so far? The attached is my Signal Express project. Thank you.
04-03-2009 02:57 PM
04-08-2009 05:00 PM
Doug,
The following are all of the tests I did.
With no averaging (Sometimes signals look bad.)
Channels; Samples;Sampling Rate (Hz); Magnitude(dB);Phase (deg); Coherence;Time shifts(second);
1&0 4096 16384 See Fig.1 See Fig.2 1 -
1&0 24000 24000 0 +/- 5m 0 +/- 50m 1 -
1&0 50000 50000 0 +/- 5m 0 +/- 50m 1 -
With RMS averaging
Channels; Samples; SamplingRate (Hz);Magnitude; Phase; Coherence;Time shifts(second)
1&0 4096 16384 See Fig.3 See Fig.4 See Fig.5 10.15u
5&0 4096 16384 See Fig.6 See Fig.7 See Fig.8 10.1u
1&0 24000 24000 See Fig.9 See Fig.10 See Fig.11 6.69u
5&0 24000 24000 See Fig.12 See Fig.13 See Fig.14 6.6u
1&0 50000 50000 See Fig.15 See Fig.16 See Fig.17 3.3u
5&0 50000 50000 See Fig.18 See Fig.19 See Fig.20 3.3u
As the frequency goes higher, the coherence and magnitude dropped and the phase increased. 16384
Hz is still a special frequency to the AD converter.
The figures are in the attached files. Thanks a lot.
04-09-2009 05:00 PM
05-03-2009 09:00 PM
Doug,
Thank you for your reply. I ran my tests with other frequencies from hundreds Hz to 50kHz and didn't see lack of coherence. 16384Hz is the only odd frequency in my tests. I am not familiar with the harmonic frequency of the circuitry. Would you please explain more about it to me?
Thanks a lot.
05-04-2009 03:01 PM
A resonant frequency is a characteristic of any circuit defined by the physical characteristics of its components. It basically means that at that frequency a very small input frequency will become a very large output frequency.
http://en.wikipedia.org/wiki/LC_circuit#Resonance_effect
