10-01-2008 09:12 PM
10-02-2008 11:11 AM
Hello Steve,
There should be a VI in the 'Getting Started' example called 'Initialize with Options'. Open that VI up and see if there is a true constant wired to the 'Reset Device' terminal. If there is, that is the reason that your sweep reinitializes every time.
Thank you
10-02-2008 11:27 AM
Hi, Ryan:
I'm not at my computer at the moment, but I don't believe SignalExpress has an Initialize with Options VI does it?
-Steve
10-02-2008 12:01 PM
Hello Steve,
I did not realize you were using Signal Express. I will continue to look into why this is happening.
Thank you
