12-08-2008 09:13 AM
I would like to view a signal in Signal Express 3.0 in a "waveform chart" but don't know how to do it and I am thinking that it may be impossible?
In Labview there are two ways of viewing data, either in a "waveform chart" or in a "waveform graph". The great thing with "waveform chart" is that it lets you define a history length and you can see the data move to the left (strip chart option) as the samples are being retrieved. It works perfect.
In Signal Express I can only select "XY graph" or "Waveform graph" by making a right-click the mouse but I cannot select "Waveform chart". Is it really true that it is not possible to view the data in a "waveform graph with Labview SE? (1 analog signal being read continuously, 100 samples to read at 1K rate)
Thank you in advance,
Enrique
12-08-2008 09:25 AM
Hi Enrique,
You are correct that there is currently no waveform chart in SignalExpress. The closest thing you can get to, is recording the data as a log and then viewing it while recording (which I realize is not quite the same, interactive behavior).
For your last comment, you wrote "waveform graph", but I assume you meant to say "chart" there as well.
Sorry about this. We have recently been getting this request, so perhaps in a future version.
Phil
12-08-2008 10:10 AM
Hi Phil,
thank you for the fast reply. Sad that SE doesn't support "waveform chart" but that's the way it is.
Yes, you are correct in assuming that I meant "chart" instead of "graph" in my last comment.
Enrique
