SignalExpress
How to use USB-6212 with LabView SignalExpress
One more question.
When the Configure Run to a fixed time at 1000 seconds for DA conversion, for eaxmple, if the data length is less than the programmed time 1000 seconds, for eaxmple 900 seconds, some unexpected signal was coming out until the time expired. Is there any tip to avoid this behavior?
Message 11 of 12
(2,880 Views)
If I understand you question correctly, you would like to be able to stop aquiring or generating data after if you essentially run out of good data.  If this is the case, you can set a stop condition on your aquistion or generation by going up to your recording options in the generate or aquire steps.  You can then set a conditions where if you data becomes bad or outside a certain threshold, you can then stop recording or generating those data points.  I hope this answered your question.
Brian P.
Message 12 of 12
(2,872 Views)
