06-14-2016 12:53 PM
I have limited experience with SignalExpress. I have created some large data logs (around 10 GB) over an hour of recording. I have figured out how to do a power spectrum over the whole log, but what I really need is to do are power spectrums at some interval. So after some period of time I don't care about, I want to analyze a second or two of data (or some x samples would be good as well). If SignalExpress can spit graphs out as images or something else I can use, that would be great.
To take this a step further, the logs have multiple elements in them. If I can automate the analysis so each element is done seperately, that would be great. But doing what I asked about above where I have to manually select the element would still be sufficient for my needs.
I am sure someone has asked about these things before, but after days of searching I have come up empty handed. Thanks for looking and any direction you can provide.
06-15-2016 11:57 AM
Do you have an option to use LabVIEW over SignalExpress or are you limited by SW?
