08-11-2015 12:02 PM
I am using a NI USB-6210 DAQ and SignalExpress 2014. I am using DAQmx Acquire in SignalExpress to get the signals. How can I change the X-Offset of the Voltage sine wave that I have from DAQmx Acquire.
Thank You,
Nik Nelson
08-13-2015 11:54 AM
Hi there,
Can you attached a screen shot to see what is going on wtih your SignalExpress?
Does your signal have an offset by it self? If so you can refer to this white paper
1- How Do I Subtract a Constant Offset Value from a Signal in LabVIEW SignalExpress?
http://digital.ni.com/public.nsf/allkb/555B4791612E261E8625763F0031DC2C
Also you can take a look of this white paper
2- Zero Offset
http://zone.ni.com/reference/en-XX/help/371268M-01/expresswb/zero_offset/
Regards
08-13-2015 02:35 PM
I was about to get the offset to work when i used step "Interactive Alignment" and change the value in "Alignment"->"X-Offset". I also change the value in "Operator Mode", but whenever I disable Operator Mode, SignalExpress automatacally changes the "X-Offset" to 1.100. Why does the X-Offset value keep changing without me changing the value in operator mode? Is there a way I can fix it?
Thank You,
Nik Nelson
08-14-2015 05:18 PM
Hi Nik,
I did a project in signal express to try to simulate your issue, but when I chose the step "Interactive Alignment" by the X offset was set in 0 by default.
In you case if you set the X offset to 0 and run the task it changed to 1.100 automatically? and this happened when you have the operator mode disable only?
Can you change the X offset mean while the task is running?
Regards
08-17-2015 09:08 AM
Yes I can change the offset manually while in operator mode, only on the operator interface. Then when I click on "Disable Operator Mode" and run the project again, it changes the offset to 1.100 and will not let me change it back to 0 unless I uncheck "allow x-axis offset"
Thank You,
Nik Nelson
08-18-2015 05:28 PM
Hi Nik,
So unchecking the "allow x-axis offset" and turn the offset to 0 works for you?
If you try to create a quickly task in MAX to see the signal that you are acquiring, does your signal have the same offset that you are seeing in SignalExpress? or this happened only with SignalExpress?
Regards
